  #26 (permalink)
Old 11-19-2014, 07:37 PM
Ohio Ken Ohio Ken is offline
Cobra Make, Engine: Classic427 351w
Originally Posted by MaSnaka View Post
I replaced the 9" Pinto discs on my CR with the Wilwood 11" 4 piston Dynolites. I think I dropped about 20lbs per wheel, number is a little fuzzy but it was significant. I also changed the pedal ratio which made a huge difference. There are pictures in my gallery of the mods to the brake pedal. Stopping improved greatly. Later I replaced the rear drums with 11" Wilwoods, new master and proportioning valve. I didn't notice a big change in stopping ability but I am glad for the upgrade.
John
Hey John
On your rear disk wilwood 11", did you use the 2-1/2" offset for 8.8" axle?
This looks like it would reduce my current offset (drums) by 1/2 to 1". I wouldn't mind moving my tires inward a little, but not sure if tires would rub inside the tub. My tires are P295/50R/15 mounted on am racing shelby knockoff look a likes . Do you remember the wilwood P/N?
