I have used Photobucket for quite a while, and after the software update it was harder to maneuver around the updated site at first, it's just a minor learning curve.
Any pic that is loaded to the site, move your cursor to upper right corner then click on edit then click on orientation then rotate your pic as needed, then save it, then copy & paste away.
I rotated the pic of the head for you and tried to post it, but Club Cobra won't let me post pic's yet.
Brent couple of questions, but first I wanted to say how you made me laugh when you were referring to the Diamond pistons pin height and the cranks short stroke, referencing a stock stroke as a short stroke crank, and I know it may seem that way to you now after all the stroker motors you have built, but it did make me laugh...
I was wanting to know what the weight of the crank is and the weight of the pistons ? The reason I am asking is I have a factory steel crank but mine has 2 extra counterweights off the center main, so I was curious as to what one weighs with out the center weights.
Thanks
