Height of sidepipes off the ground
Hi,
I am building my own operational sidepipes and currently looking at positioning. The OD of the large pipe that I am using is 4". I am thinking of having the bottom of the pipe 40mm higher than the bottom of the chassis (lowest point of the car) so this would make the bottom of the pipes about 150-160mm off the ground, is this inline with what you guys with similar pipes have?
It's very hard to work out height from a looks and stance perspective when the car is on jack stands.
Ben in AU
