Old 11-23-2014, 08:59 AM
bkozlow bkozlow is offline
Cobra Make, Engine: built the molds and body composite construction
If at all possible consider putting your system forward of the brace, then angle the collector towards the position of where you want to come out on the side of the car. I see your present system as building a large heat sink, which will cause you fluid problems with heat build up in the future. The orginial Daytonas had asbestos shields to stop heat from getting to the fluid cylinders.
Bill K
