Old 11-25-2014, 06:26 AM
strictlypersonl strictlypersonl is offline
The amount you can lengthen the trailing arm is limited, since it changes the pinion angle when you do. It would be nice if you knew what your pinion angle currently is (at normal ride height). I'd try to keep that angle within 2 or 3 degrees of the tilt of the engine/trans.
