FE Harmonic Balancer and Pulley?
My stock 427 fe harmonic balancer has a single integral v pulley(about 6.5" dia.), which is attached to the assembly, and the whole assembly is held in with one bolt to the crankshaft.
While removing the cast iron water pump to install an edlebrock aluminum water pump, I noticed the original aluminum water pump pulley, will not fit the edlebrock water pump. The spacing for the 4 bolts is wider on my original aluminum pulley. What is needed to install the edlebrock aluminum water pump? I already have given you information about my harmonic balancer above. I have already called edlebrock to see if there was an error on their 8805 water pump, but everything checked out.
Please Chime In,
Tom
