Old 11-27-2014, 10:18 AM
wrench87 wrench87 is offline
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
There should be a little reverse unit that mounts to the speedo, you have to remove it and clean and lube it.
I read somewhere that the cable ends are a little to long and when you tighten the cable it binds up and doesnt move freely, some have cut a tiny bit off the end so it does not bind.
factory five mk III roadster, 445 fe stroker
