Zedn,
I have bled tremecs a few times. its a crock. especially when you are alone.
This is what I do now.
Go to Kmart.
Buy $12 fish tank pump with the inlet and outlet tube, cheep nasty one, it even comes with a meter of clear plastic flex tube.
Make Coffee or obtain other beverage.
Connect the flex tube to the inlet port, no barb on this end.
Connect the other end to the bleeder nipple on the slave cylinder.
Top up Master cylinder Res.
Put the pump in an ice cream tub, remove ice cream first.
Crack the bleed nipple.
Pug in the pump, 240v and turn it on.
Drink coffee, or other beverage.
Top up Res periodically before it sucks air.
Watch tube till bubbles no longer appear.
Tighten bleeder tube nipple.
Check for clutch actuation.
Repeat if necessary.
Dispose of pump.
Dave
http://cobra-cr3514.blogspot.com/
