  #25 (permalink)
Old 11-28-2014, 05:55 PM
gjkrv8's Avatar
gjkrv8 gjkrv8 is offline
Quick question - slightly related - Could you fit one of those bleed extension kits whilst the gearbox is attached to the engine (e.g. without separating them). Or would it be too messy and you would run the risk of fluid leaking into the bell housing? (or could you drain most of the fluid out first). Just trying to see if I could retrofit one without pulling engine gearbox apart. Curious only at this stage. Cheers Gregg
