Originally Posted by deano59
cheers for that im not in a hurry heck I don't even have the car yet :-) I still have the pedal loom and plug from the ve could I splice that into the psi loom you think ?
cheers dean
Yes, that would be perfect. You can just cut the wires and solder the pigtail from the VE on. Easy job.
I would probably still buy the PSI harness again despite my disappointment with their service once i found the VSS plug missing. There are some bad reviews floating around the net about the wire used, but there are also a lot of good ones.
I was going to make my own, but then after pricing up the materials found it was actually cheaper to buy the PSI harness.
GMPP is the other option which comes with the controller and pedal also. My only concern here was the emissions, but i think there have been people who have passed the IM240 test with one. The other thing is they use a different model of ECU.
Good Luck.
Liam
