This issue is directly related to the quality of the resin, and the quality control in mixing the resin. If your body isn't stable after a year, you can pretty much bet on it never being stable. Without knowing the specific resin they used, there is no way to determine if your issue is a material defect, or just cheap materials that shouldn't have been used in the first place.
Is the inverse also true? If you have no issues over that year, are you likely to not develop any subject to proper finish and regular care?
The older I get, the faster I was.
