Petek,
It's obviously to late to put the "bends" in the lower portion of your bar. Extensions coming off the frame with the bend are a possibility, but to me that would be very difficult for you at this point.
On all our Cobras we build, we take a 3/16's 3x3 or 4x4 piece of angle and weld it between the frame rails, right behind the right behind the square tube that your roll bar would normally sit on.
I don't know if this would work for you, but it would be worth checking out. (We've even welded these angles in on finished cars.)
If this is as clear as mud, feel free to call. If it would work, it certainly would be the easiest solution.
DV - 300 Cobras is NOT enough!
