Old 12-05-2014, 01:33 PM
frankym frankym is offline
Cobra Make, Engine: ERA 575 with Shelby Aluminum 427 Stroked to 468
dan, you rock! thanks for this info, very helpful. If i understand tire measurements your tire height above the rim is 60% of 255mm, or 153mm. My tires are 50% of 295mm or 147mm. So you have a very very squat look, your tire should probably actually be recessed a little into the fender well. I am going to see what i can get away, i may need to go 25.5 measured in the rear. obviously it will be a little trial and error and avoid doing damage from the bell housing getting too low.
