Old 04-17-2002, 06:40 AM
jams's Avatar
jams jams is offline
Cobra Make, Engine: B & B
Hi Tom,
I first thought I needed to use a proportioning valve but after speaking with B & B they said to use a t valve with 4 wheel disk. I believe you only use a prop valve with a combination of disk/drum brakes. I took my advice right from B & B so that is good enough for me.
I have not had it on the road yet but I am sure it will work fine.
Good Luck
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
