Need some guidance before I proceed
Ok, the time has come to weld together my 289 forward braced roll bar. But before I proceed with what I believe is the correct approach, I would like the pros to chime in.
I plan to cut the forward brace about 8" from the point where it welds to the hoop. Will then weld the insert into the top pice with a series of rosette welds. I will then put the two pieces together and drill the holes in the bottom piece to secure the two pieces.
Next I will install the hoop and align the brace, tack weld, remove, and final weld.
Let me know if this is the correct way or not. I plan to use 5/16 grade 8 bolts (2) to secure the upper and lower portions of the forward brace
Thanks
Bill D
