Old 12-09-2014, 10:38 AM
wrogers55's Avatar
wrogers55 wrogers55 is offline
Cobra Make, Engine: Backdraft #318, 418 CI, 532 RWHP, Mass Flow Injected, TKO600-Road Race, BMW M3 Suspension, Race Springs (Wouldn't do it again, rough on the street).
Neutral
Definitely not enough caster or the rack is binding. As a quick and dirty test, just jack it up and turn the steering wheel slowly lock to lock a few times and feel for any binding. There isn't much droop in the Backdraft fronts jacked up so it's not a perfect test, but will tell you if there is an obvious problem with the rack.
Then have it aligned with a special emphasis on caster. You can set the caster to you liking to self center, more as opposed to less is always safer but takes a little more effort initially.
When you get it right, that Backdraft will be a real pleasure to drive!
Wayne Rogers in Hideaway, Texas
