I'd do a quick alignment check, but I'd still be putting the car on a hoist, disconnect each tie rod end to isolate each steering knuckle from the rack. Now you have each knuckle, top and bottom ball joint to test (left and right), and the steering rack/steering input shaft to test, each independent of each other. The alignment would have be a fair bit out to not self centre, either not enough castor or insufficient toe-in. I've had cars where one other tech has fitted a rack then it needs a wheel align. He says should be close. Drive like rubbish and would keep turning into corners because of massive toe-out. Of course the car driving as badly as it did would scrub the tyres out in 50km if you left like that.
How does your car drive otherwise?
Gary
