Old 12-13-2014, 01:20 PM
Turbonut48 Turbonut48 is offline
Cobra Make, Engine: 1968 GT350, FFR Daytona Coupe
Default Oil Pressure
The accumulator pressure needs to be less than the engine oil pressure at start up. If you have more than 60 than you should be good with 60 psi. Otherwise reduce to 40.
Maybe the valve is leaking and not holding your pressure between runs.
The Nut
Enough is enough. Too much is just right ( C.S )
