Old 12-14-2014, 05:36 PM
SydneyChris SydneyChris is offline
Default FFR Coupe 65 in Sydney
Hi all..
Am progressing on a Sydney build of an FFR Coupe 65 and was referred to this forum for networking and local build tips..
My Coupe spent a month or so in fabrication, with a swap to RHD, new mounts for an LS3 and TR6060 drivetrain.
Have fitted a BA Falcon adjustable steering column, connected to a Subaru Liberty power rack.
Brakes are AU spec Willwood units, with a MBR 7 inch single diaphram booster and master cylinder c/w proporting valve.
Have sheeted the new footwell cages I built with 3mm AL for some crash protection as well as lined the exterior with zero clearance heat shield and dynamat on the inside.
The rear end is an IRS set up, 8.8 inch Ford center, fitted with a Torsen LSD and a 3.55:1 gear set.
Seats have been the biggest issue so far. The Kirkeys that came with the kit obviously fit but are not ADR approved. Have tried three sets of seats so far with no success, mostly because the rear of the cabin is tapered (and the structural upright from the mail rail is vertical and not reclined).
Any input on this issue would be appreciated as an ADR approved seat is required for road registration.
Fingers crossed I will be able to knock off the electrics over Christmas, at least sufficient to get to gokart stage to do a bit of shakedown testing on the driveline and BA Falcon ABS unit I have installed at the mo.
Chris
