As a general observation aligned I think with other sentiments already expressed, if you're operating in an environment that deems the coolant's use as valueable, you are happy to pay way above the odds for the fluid, you are happy to be potentially incapacitated if you need to top up fluid and don't have sufficient or need to top up after any service and you think you will have so much life out of the engine that you do want to prevent against corrosion over the next 20 years. Go for it!
Personally it seems a good idea but not worth pursuing for normal operating use.
My 2.5c worth
slowy
