Old 12-17-2014, 09:29 AM
HSC-ZL1 HSC-ZL1 is offline
Default heat movement
I would not mess with the wheel wells. I have an all aluminum big block. I made a pair of aluminum shields with reflective insulation that I mounted between the wheel wells and the fire wall the deflect header heat from brake and clutch hydraulics. A shroud and high volume puller fan to move air around and out of engine bay. Motor runs about 190- 192 on 90 degree days.
