Brett,
I do not know what pedal assembly you have. Either the Tilton or the Wilwood units fit the pedal box.
Each one uses a different adjuster cable.
If it was my car I would fab up an electric drive for the cable so that it would be easy to adjust between corners. Pretty easy to do and inexpensive as well. Just a simple DC gear motor, a cable, and a switch mounted on the steering or the shifter.
Of course one would probably wish to have programmable position stops but this would be pretty easy as well. A op-amp, a rotary pot, and a logic chip should do the trick.
I am sure that you have some EE buddies that could whip out the circuit for you.
