Old 12-27-2014, 11:23 AM
Tom Wells's Avatar
Tom Wells Tom Wells is offline
lastdime,
It would seem the 150-750 hasn't a built-in dipstick.
All the 429-460s I've seen use either a front cover (timing chain cover) dipstick, which would likely work with that pan, or a pan-mounted dipstick.
You can buy a different front cover for your engine with the dipstick provision; just be sure to get a dipstick with it - they are getting hard to find. The covers can sometimes be found at a junkyard, or bought as aftermarket items. The dipstick in the cover is located toward the passenger side of the water outlet. If your engine is out, this may be the simplest solution, otherwise replacing that front cover in the car could be a fair chore...
Option 2 would be to send the pan back and get an equivalent one with a dipstick in the pan. Typically the pan-mounted dipstick is on the driver's side and is usually placed where it comes up between the primaries of the header on that side.
Option 3 would be to check with Lokar or one of the other aftermarket folks (maybe Canton too?) and see if they make a dipstick that could be added to your pan, most likely on the driver's side.
Enjoy solving this problem! There may be one or two others along the way, so don't get discouraged...
Tom
