Old 12-27-2014, 01:58 PM
66gtk 66gtk is offline
Originally Posted by vatdevil View Post
Superformance optimum settings are 27 front and 26.5 rear. I use that as a starting point and verify with frame height. Bodies aren't always identical from side to side. Or, better to measure from fender to bottom lip of rim, which is 22.50 front and rear, assuming 15 inch rims.
I'm at 22" at 3 corners and 22.5" at the LR corner when measuring to the bottom lip of the rim. I'm running the stock tires and my floor to lip height is MUCH higher. 27-28" all around.... Looks too jacked up. I have about 32 psi in the tires for winter.
I think I'm going to change to 295/50-15 in the rear and 235/60-15 in the front to get the car a little lower to the ground when I need tires.
