  #33 (permalink)
Old 12-28-2014, 11:47 AM
Mark IV Mark IV is offline
Senile Club Cobra Member
If you contact me I can forward the Superformance Install Manual and a list of needed parts. A read through this will answer your questions on procedure and degree of difficulty. We also have some "tips" that our installers and customers have come across over the years that we can provide.
No special tools are needed, but some can help, i.e. a set for installing Airquip type hose ends will save time and reduce the stainless steel finger punctures so common when working with this material.
Theoretically you can do an complete build out in eight hours.....in the real world not so much. Figure 20-24 hours not counting hardware store trips, beer breaks, etc. If you have EVERYTHING you need sitting next to the chassis it goes fast but in our experience this NEVER happens! You will lose a nut, need a fitting that the engine supplier did not provide, etc. so plan on some trips for parts. And then you need to have the alignment set unless you are equipped to do this.
Again, call or email for this documentation.
Rick
We can supply a fitted install blanket for use to our customers for installs, so far it has been used many times!
rick@autoventureusa.net
