  #37 (permalink)
Old 01-01-2015, 11:42 AM
AL427SBF AL427SBF is offline
Originally Posted by Thor maine View Post
So what is the feeling on a small block stroked to 427 cubes? (Ford or Chevy or Mopar)
Start with the exterior shape, it's called a 427 body. If you have the correct fender emblems they say 427 Ford Cobra. From there it becomes simple -
... If you have a Ford in it and it's a 427 CID motor then you can check that box.
... If it's a non-Ford 427, sand the "Ford" flat on the emblem and you will be ok, letters are slightly raised and unpainted so no one will notice.
... If you have a BB with more than 427 CID, any make motor, then you are SOL as it is the wrong size motor for the body.
When patrickt heads out for a cruise in his 440 BB, all his little buddies know he is behind the wheel of a rolling lie
