Old 01-02-2015, 05:41 AM
DanEC's Avatar
DanEC DanEC is offline
If using a 289 motor you probably don't need the higher capacity cooling fan. ERA provides a good sized radiator and the standard fan would probably work fine unless you have some really hot weather.
Twoshelbys brings up a good example about the roll bar. if my car is typical, it included the mounts for the driver side roll bar, although I ordered a street roadster without the rollbar. If you may want a passenger side bar then that needs to be fabricated in at their shop.
ERA 782 Running
