Taking the body off
I'm waiting for a hood hinge assembly from Bruce before I can remove the body and start fabricating the aluminum panels. The body needs to be on so I can properly locate and weld everything. Since I don't know when the hinges will be delivered, I'm wondering if I take the body off now to do the panels, lay out the brake and fuel lines, lay out the wiring, etc. will I cause problems with installing the body and taking it off again later. In other words, will removing/installing the body several times before paint be bad for the body?
Thanks
Bill
