Thread: Cooling issue
Old 01-11-2015, 04:33 AM
Mdman352's Avatar
Mdman352 Mdman352 is offline
Cobra Make, Engine: Contemporary-427 stroker
#5 from Rick Lake.
Use a (shrouded from the factory) fan from a Lincoln Mark VIII. Use only the high speed, as it is a 2 speed fan. Use a heavy duty relay and appropriate wire size as it draws 45 amps (?). Cured my FE issues. Also, you will definitely need to upsize your alternator.
