Thread: Emergency brake
Old 01-12-2015, 02:04 PM
Rjscharer Rjscharer is offline
Cobra Make, Engine: Backdraft
Default Emergency brake
New build number 1368 emergency brake fails to hold. I tightened up the two
bolts on either side of the handbrake lever. I also took it to a local shop and
put it up on a lift. The fittings on each of the rear wheels were tightened to
the point that the wheels were almost non rotating,then the fittings were
backed off some so that the wheels turned freely. When lowered to the ground,
the emergency brake failed to hold. Anyone else experience this?
Thanks
