Originally Posted by frankym
the top may be of little interest to you, but it helps with resale, plus, i believe they fit the actual top onto your car, and you might have a tough time doing it later.
This. If your budget is tight on this one and you know for sure you will never use it (no long distance trips planned?) you can certainly save money. For some reason I thought the tops were standard now on the SPF Cobras. If I didn't have a top, I would try and order the car without all the lift a dot tabs and ferrules on the doors. Can they do that?
