  #67 (permalink)
Old 01-16-2015, 02:42 PM
RodKnock's Avatar
RodKnock RodKnock is offline
Originally Posted by Dimis View Post
Unless I'm mistaken Barry has a set of heads that fit both 390 and 427 bore sizing. Crank & rods could be recycled. As could intake, ignition & distributor, other miscellaneous parts like alternator, pulleys, Oil, water & fuel pumps lines pans... etc... All reusable Id have thought. No?
One could spec a carb that would accommodate both (with jetting changes), like a QF 700 or similar.
Pistons and rings, I defer to the pros...
But seemingly an upfront saving of about $5k block.
You would use the same carb, heads, intake, cranks & rods from a 390 on a 482 build? First and foremost that's an additional 92 cubic inches and second I don't think alot of those parts even fit on both engines.
