Thread: Clutch HELP!
Old 01-17-2015, 06:29 AM
cobraman428 cobraman428 is offline
I would also suggest staying away from a clutch cable system. I would install a hydraulic setup. Go out and purchase a master cylinder and slave cylinder and some brake line. Research though on the correct bore diameters or each as that is important. Also you will need to get the length of travel set up correctly on the clutch. Good Luck.
