Your getting to much traction on the driver side (left).
Check tires to make sure you have the same pressure on both sides.
If you have adjustable coil overs on the rear you can raise the driver side a little to shift weight to the passenger side.
Trial and error
Mine pulled to the right. I bought adjustable QA1 coil overs and increased the pressure on the passenger side by two click and decreased by two on the driver side. It now pulls straight
Dwight
