Originally Posted by joyridin'
I am putting a LS3 in my Arntz and am having a problem with the alternator. I need the set-up with the alternator low, but the only kit I found is $2k. Beyond my price range for what it is. GMPP makes a lit, but the alternator is so high, I think it will hit the hood!
Just for curiosity, can you take the whole shifter assembly off the 6060 and mount a shifter right on the trans? I currently have a T56 with the linkage flipped and the actual shifter mounted on the inspection plate about 12" from the bellhousing. I do not see any way of switching to the 6060 the way the shifter is mounted.
Core shifters makes a top mount shifter for the 6060. You remove the top plate that holds the shift rod and it installs in its place. It was to far forward for the cobra thats why I used the stock one.
