  #122 (permalink)
Old 01-26-2015, 02:32 PM
Xack's Avatar
Xack Xack is offline
Cobra Make, Engine: West Coast Dreams
Default confusion abounds
I just had a thought (no snide remarks please) - the people who have chimed in on this thread and said LEDs work in their tail lights in ERAs, have the round tail light option which I believe uses 4 bulbs instead of one being a reflector. Kevens2 has round lights, I know Patrick does, I think Large Arbor does. I have the rectangular tail lights with one bulb each.
Possibly, it takes the 4 LED lights together with the front ones to create the resistence properties necessary for everything to work. Without my parking lights on there just isn't enough load in the system and something is going wrong. When I turn on my parking lights the extra load on the system brings everything on and it works fine.
Is there anyone out there who hasn't given up on this thread already, with rectangular lights and had sucess with LEDs in the tail lights.
Patrick and Dan,
Dan, You did mention that you have 4 blinker relays? or 2? or 1? In most cases the blinker has at least 3 incandescent lights in a normal circuit. Front, Rear and the dash indicator. If you have a blinker relay for each light, the problem may be that each relay only has one LED for it's load. It's not easy to tell from the discussion. Most LED distributors sell loads for the LED blinkers to operate correctly. Do you have something like this installed? However it seems this is the opposite problem... Normally the load is needed to get the relay to blink. All your lights are blinking !! ??? I am cornfused!
