Originally Posted by blykins
That is correct, two lengths. QuickTime bells are available for either and if you change to a short shaft and bell, the shaft will need lengthened.
Well I do not know which shaft length this one is yet, so all this may be a moot point.
I was kind of hoping the drive shaft would do, but doubted it. Then I found out the difference is 1.2". So much for wishing.
It would move the shifter forward about 1.2" too. I think this transmission can have the shifter mounted several places, but I don't know the spacing difference in those positions. Is that just a "how you assemble it" change or does it require different parts?
I guess what I'm trying to figure out is: if it is the opposite shaft length from what I have, would it be cheaper to buy new parts than changing everything.
PS
I would consider going to a shorter shaft, but I would not go to a longer shaft. I wouldn't shorten the drive shaft, any, but longer would be nice.
