Originally Posted by 750hp
David, it would have been interesting to have then compared a drop base filter assembly or a 2" filter, because the problem is usually that you can't fit a 14x3 in a Cobra like you can in a tintop.
This engine went into my 1965 Mustang Coupe road racer,same one in my avatar.......
The air filter housing actually was a drop based filter...on the Mustang,you can run a 2" filter and it will fit under the stock hood,barely.......I wanted at least a 3" filter,so I had got a drop base filter housing of 1.5"s and that is what was used on the dyno and the car.....
David
