Old 02-09-2015, 03:57 AM
Default It depends on abuse
Kevin2 Kevin if you are hard on the car, every 1000 miles. This also depends on driving conditions like rain or track abuse. If normal driving every oil change or 3000miles which ever comes first. Also and very important, wheel bearings, repack and adjust for fronts and check hub bearing play on rears if running a Jag setup. The rest is a once a year maintainance check of the whole car with nuts and bolts being checked. There is about 12-15 grease fitting on the car with a jag setup. Unless you have a lift, pulling the tires will be needed to get a good shot at all the fittings. I use the red hitemp from Lucas for all my fittings and joints. Good luck. Rick L.
