Originally Posted by mikiec
Looks like carb may need an overhaul, squirters are not working. But then again they may not like negative temps.
I'll wait til spring to check it further,
Nothing to worry about, just frozen gas. Did you know if you take the accelerator pump housings off, you end up with these little gas ice balls that you start a snowman with. In the spring, they will pass gas.
