Old 02-16-2015, 10:43 AM
strictlypersonl strictlypersonl is offline
The headlight dimmer relay is only connected to the headlight circuit. Nothing there is connected to the signals. That would indicate something really weird happening within the signal wand. Considering the headlight flasher switch wiring is completely independent of the signal circuits (theoretically), the likeliest thing is a pinched wire. Did I ever send you a new wire module from the under-dash module to the main harness?
