  #57 (permalink)
Old 04-21-2002, 06:07 PM
niles niles is offline
Cobra Make, Engine: Hunter #28; 396 Cleveland stroker; more than 495 HP; TKO 5 speed
Default oil
justa6;
You might not need a oil cooler; because a dry sump has more oil volume and the lines and sump are in effect an oil cooler.
BUT: Also DV; make sure to calibrate your oil sensor; just because it reads 140 deg? that means absolutely nothing; work on double checking and verifying the actual temperature.
Sensor and guages are notorious for leading one on all sorts of wild goose chases .
gn
