  #23 (permalink)
Old 02-28-2015, 03:23 AM
Default Great ideas
RACERAL Aluminum flywheel is great, How about a 22 pound flywheel? The rotating assembly in the motor was setup guessfor "0" weight needed or removed. This is one thing a have always done with bottom ends and had the whole thing setup and checked. Have we looked at a clutch setup yet?? If you are an easy driver, go with a stock 11" setup. If looking to be a little silly, I recommend a street twin. Lite pedal, good feedback, last the life of the motor if setup right with a hydro TOB. IMO The abuse part I want to break or take the most abuse is the clutch. Cheapest thing to replace or other parts and takes alot of abuse too. If you go with stock setup get the spring hub disc. Rick L.
