Old 03-01-2015, 07:52 AM
bobcowan's Avatar
bobcowan bobcowan is offline
Originally Posted by Lou1119 View Post
The saga of my Superformance Cobra rebuild goes on. One of my oil filters is leaking.
Thanks
The problem is rarely the filter. If it was, the problem would go away when you changed the filter. If you're not sure, switch positions of the filters.
The problem is in the cast aluminum base. Single or dual, they often leak for a variety of reasons: the base isn't flat, the base has imperfections, or it changes shape with the heat.
You could clean it really well, and add a slight smear of The Right Stuff. You best option is to replace it with billit components; but that's not cheap.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
