Old 03-03-2015, 04:04 PM
stephen low's Avatar
stephen low stephen low is offline
Default shed build - foundation advice
Guys
Just chasing some advice for my small shed transformation.
I had a simple 3 x 3m garden shed that became chockers with assorted crap and I started looking for a replacement alternative a long while ago.
Found a modest fleabay special sometime back and am gearing up to install the 8 x 4m replacement soon. Its a standard steel frame, hardwood beam construction and colourbond sheet affair. Frames bolt to uprights that need to be pre-concreted into place.
Have planned on pouring a slab that is 150mm thick but with an additional 50mm beam depth, some 300mm inwards from the outside edge, ie an edge beam of 200mm thickness.
Am thinking down the track the shed might house a car hence the edge beam treatment but do want to put in re-inforcement too.
I am thinking just 1 layer of reo but what sizing do you guys suggest?
The old 3 x 3 was just 100mm thick and without reo and performed very well, including resistance to being chopped up - ha
After suggestes lads please.
slowy
