Laser cutter - steel - seeking some brackets to be made
Hey guys,
Just checking to see if anyone has or has access to a laser cutter for steel. I am seeking some brackets to be cut from 6mm steel.
I know that there are places that do this, which I will use as a last resort, however was being a tight ar$e and trying to save a little as I am only after two brackets styles, 4 pieces of each.
This is for from shock mounting (upper and lower).
Cheers.
