I debated between the Hobart 210 MPV and Millermatic 211 both duel voltage, 110/220 and can weld 3/8 in one path. I then found lincoln came out with a new multi welder in November which can TIG,MIG,Stick,Spool gun for $999. TIG is dc only so no aluminum you would have to use the spool gun. It only weighs 48 lbs vs 90 lbs for the Hobart and Millermatic. You can get the Hobart from Northern tool with online coupon for $920 the millermatic 1045 at welders supply free shipping no taxes so the difference in price is within $100. The lincoln looks cool but by the time you add spool gun, TIG kit you are $1500 on a newly released machine....
