Originally Posted by madmaxx
TIG is much harder than MIG. ...
This should not be a deciding factor. Get the machine you need for the type of work you are doing. TIG is only harder because there are no good tutorials on how to weld with TIG. Go play with TIG. When you can't figure out what you are doing wrong, buy and hour or two of a local welder's time and you will get the tips you need. Once you know how, it's just as easy and much more versatile.
