Old 03-15-2015, 12:40 PM
PeteF's Avatar
PeteF PeteF is offline
Cobra Make, Engine: ERA2041 sold 2021
Sounds like bad fuel (you mentioned a bad smell), or contamination in the fuel bowls. I assume you have a good filter installed. The only things I could recommend now is to spray some Seafoam through the air bleeds of the carb, and/or pull the front bowl and look for debris. Good luck.
