Old 03-19-2015, 07:04 AM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
The T-5 oil should be red Dextron II or III. vref120 is right, if it's engine oil the flywheel bolts require sealant on the threads. They go right to the oil pressure side of the crank on the SBF. If you replaced the rear main seal did you put silicone between the main cap and the seal. You can't do the silicone on upper with the engine in.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
